Group: DynoMotion Message: 9288 From: Toby Rule Date: 3/3/2014
Subject: Deadlocking in KMotion library
I think I previously mentioned that my application sometimes deadlocks in KMotion library calls when the USB cable is unplugged/replugged. I did some more debugging, and found that making the following changes seems to fix the problem.  I'm using KMotion 4.31f.
1) In KMotionDLL.cpp, in CKMotionDLL::GetStatus, I added "ReleaseToken();" before four occurrence of "return 1;".  Apparently the application sometimes called GetStatus at about the same time the board disconnected, which caused GetStatus to return an error without releasing the token.
2) in KMotionIO.cpp, in CKMotionIO::ReleaseToken, made the following change.  Apparently, under certain conditions when unplugging / replugging the USB connector, Token became less than zero, which caused KMotionLock to return KMOTION_IN_USE
void CKMotionIO::ReleaseToken()
Mutex->Lock();
Token--;
if (Token < 0) Token=0; // ADDED THIS LINE TO ENFORCE Token >= 0
Mutex->Unlock();
Toby
Group: DynoMotion Message: 9294 From: Tom Kerekes Date: 3/3/2014
Subject: Re: Deadlocking in KMotion library
Hi Toby.
Thank you.  I don't like doing #2 as nothing should Release the Token without obtaining it.  But I can't find a case that is causing it so I guess it is better than a deadlock.  Both changes will be in the next Version.
Group: DynoMotion Message: 9296 From: Toby Rule Date: 3/4/2014
Thanks Tom.   Sorry I couldn’t get you more info on exactly what was causing issue #2.
Toby
Group: DynoMotion Message: 9306 From: fireup_kev Date: 3/4/2014
Can you make an install for version 4.31t with this update. I try to get all the patches for version 4.31s but it would be cleaner if it was one file. Thanks.
Kevin
